Sophix TAB-730g Screen Replacement
  1. Sophix TAB-730g Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the screen protector and the screen on the tablet.
    • Wedge a plastic opening tool between the screen protector and the screen.
    • Using leverage, move the tool around the entire front face of the tablet in order to break the adhesion.
    • Continue until the top screen protector pops off.
  2. Sophix TAB-730g Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is attached to a ribbon cable in the lower left hand corner marked in the picture (see highlighted area in picture).
    • The back cover of the device will need removed before continuing.
  3. Sophix TAB-730g Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  4. Sophix TAB-730g Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  5. Sophix TAB-730g Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape covering the ribbon cable's (which connects to the front of the screen) insertion point on the back of the device.
    • This will allow you access to remove the ribbon cables that is hindering you from taking off the screen.
  6. Sophix TAB-730g Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable by placing your fingers on the outside of the ribbon closest to the port it goes into.
    • Flip the black switch up so the ribbon cable will be able to come out.
    • Gently pull the ribbon cable out of the port.
JT Hiquet
crwdns2935283:009/29/16crwdne2935283:0
333 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-3, Harley Fall 2016 crwdns2935289:0IUPUI, Team 2-3, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S2G3
Where to buy a replacement screen for a azpen A848 projector tablet
gayle almond - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 600
