Sophix TAB-730g Screen Replacement
  1. Sophix TAB-730g Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the screen protector and the screen on the tablet by using a spudger between the screen protector and the screen.
    • Using leverage, move the tool around the entire front face of the tablet in order to break the adhesion and continue until the top screen protector pops off.
  2. Sophix TAB-730g Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is attached to a ribbon cable in the lower left hand corner marked in the picture (see highlighted area in picture).
    • The back cover of the device will need to be removed before continuing.
  3. Sophix TAB-730g Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover to gain access to the mother board.
    • Unscrew the 3.547 mm long screw, with a #000 Philip's screwdriver, located at the bottom of your tablet.
  4. Sophix TAB-730g Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly, slide the cover away from the ports with your hand to remove the back cover.
  5. Sophix TAB-730g Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape covering the ribbon cable's (which connects to the front of the screen) insertion point on the back of the device.
    • This will allow you access to remove the ribbon cables that is hindering you from taking off the screen.
  6. Sophix TAB-730g Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable by placing your fingers on the outside of the ribbon closest to the port it goes into.
    • Flip the black switch up so the ribbon cable will be able to come out.
    • Gently pull the ribbon cable out of the port.
JT Hiquet
crwdns2935283:009/29/16crwdne2935283:0
333 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-3, Harley Fall 2016 crwdns2935289:0IUPUI, Team 2-3, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S2G3
Where to buy a replacement screen for a azpen A848 projector tablet
gayle almond - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 623
