Sony bravia kdl40hx850 smart LED tv troubleshooting
    • before we take the tv apart we will do a self diagnostic test on the tv. See for more info in the service manual that i add to this guide.
    • for a self test on the tv , push following buttons on the remote: display button ( see picture for more info on this button ) channel 5 volume down and than power button.
    • due to data loss on my pc i lost all the pictures to make this guide.. if you have question , feel free to contact me.
    • we will open the tv. first we will remove the BUNCHIN audio undercarriage. So you can move the tv separately
    • remove the 3 screws holding the panel tot the undercarriage.
    • remove the other 3 screws as shown in picture 2
    • lift the panel ( tv) up and remove it from the BUNCHIN audio part ( sole, undercarraige...)
    • to remove the screen : do this with 2 persons and lay the tv down on a sheet ( blanket)or something.
    • when removing the screen from the audio undercarrige: whatch out for the audio cable ( remove this before removing screen)
    • like you know always make sure the tv is unplugged from the electric socket before you manipulate the tv.
    • we will remove the power supply plate.
    • it is a small black plastic plate holding the power cable.
    • remove 1 screw and slide the plastic cable holder to the left away from the plate.
    • we will remove the back plate. you have to remove 22 screws.
    • first remove the 2 screws in red. start with the screw on the left.
    • remove the 4 screws in yellow. start with the one on the left
    • remove the 14 screws in green. the 2 on the side as last.
    • remove the last screws , in blue.
    • now remove the panel
    • to remove the panel : lift the back plate towards you ( beginning with the upper side of the plate) , then tilt it to the left.
    • right is the allignment corner.
    • now you'll see all the PCB's.
    • now it's time to check out the LVDS cable or LCD cable and the LVDS connector. wiggle getnly the cable and check te tv.
    • in red de LVDS connector. attached on that connector the LVDS/LCD cable.
    • if the screen or picture is not better you can check out the diodes on the T con board. or follow the trouble shoot page in the service manual.
    • Insert wisdom here.
crwdns2935103:0crwdne2935103:0
Kevin D
crwdns2935283:005/02/14crwdne2935283:0
7,418 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
I have a CM LEDVD combo TV and DVD that will not turn on. It has power 120VAC and did work after using the DVD. Any ideas??
William Whitaker - crwdns2934203:0crwdne2934203:0
i have a 75inch tv just stoped playing sound
my bedroom tv is working great
the bell tube dings are audible
please help me
jennifer holevatz - crwdns2934203:0crwdne2934203:0
Hi!Did you ever fix the problem @kevind ? My grandma has the same TV and similar sympthoms.
Gilian - crwdns2934203:0crwdne2934203:0
my tv went all blue no pic or audio. audio is in the surround sound cant get any pic had water leak and i think some go into t he back ?? but just had dpops on it Ands we watched a movie later that night and than it kicked to blue screen any thoughts
dap2996 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,728
