Sony a7 Shutter Replacement / Complete Disassembly
  1. Sony a7 Shutter Replacement / Complete Disassembly, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera upside down, and observe where the battery door and switch are located on the camera.
    • This replacement guide is using a cardboard and tape placeholder to simulate the battery, battery door, and switch.
  2. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the switch over to the right side to open the battery door.
  3. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Depress the blue lever to allow the battery to pop out slightly.
  4. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the camera.
    • Make sure to hold onto the battery firmly when removing it from the camera, as it could slide out and fall.
  5. Sony a7 Shutter Replacement / Complete Disassembly, Rear Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
    • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
  6. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
  7. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
  8. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four M 1.5x2mm screws.
  9. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
  10. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the blunt tweezers, remove the blue ribbon cable.
    • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
  11. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
  12. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
    On my A7 the screw shown first top right was a different thread to the other three, take care to put back in the correct place
    David Zhecheva-Hamilton - crwdns2934203:0crwdne2934203:0
  13. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the metal plate and LCD screen away from the camera body.
  14. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the amber ribbon cable from the motherboard.
    13단계에서 14단계로 오는사이에 마더보드의 왼쪽 아래부분 나사 푸는 부분이 누락된것 같습니다. 아래 20단계에서 억늡한 나사 2개 이외에 아래쪽 2개를 더 푸는것을 추가해야 합니다.
    그리고 8단계 2번째 사진의 나사는 풀 필요가 없는 나사인데.. 왜 풀어야 하는지요??
    bongjae kim - crwdns2934203:0crwdne2934203:0
  15. Sony a7 Shutter Replacement / Complete Disassembly, Motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly, Motherboard: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the small adhesive tape located on the top right side of the motherboard.
  16. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the exposed ribbon cable by using the iFixit opening tools
  17. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the large black protective adhesive from the motherboard.
  18. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four visible ribbon cables by using the spudger.
    • Removing the ribbon cables will require lifting a lever located on the connecter in order to pull out the cable.
    For SD card slot replacement: Remove the bottom right flex cable. There will be a hole under the cable to access a screw in the battery compartment, which holds on the grip. Remove the screw. Remove the one remaining screw in the corner of the battery compartment. The grip should now come loose. Remove the grip. Remove the two screws holding the SD card board on. Disconnect the small two wire cable from the top of the board. The board should now slide out. Disconnect the flex cable from the old board and connect to the new board for reinstall.
    I did this for a Sony A7S and all is working well.
    Sam Hudson - crwdns2934203:0crwdne2934203:0
  19. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the one U.FL plug by using the spudger.
    • Using the spudger, remove the four remaining ribbon cables.
    • These ribbon cables do not have the requirement to lift a lever on the connector as specified in previous steps.
  20. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one M1.5x2mm screw with a PH00 Phillips screwdriver.
    • Remove one coarse threaded 5mm screw with a PH00 Phillips screwdriver.
    on my A7 there was three 5mm course thread screws marked orange, two were in the holes at the bottom of the main board
  21. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard from the camera body.
    • It helps to pick up the right side of the board first, and then work sequentially down the board. Be sure to gently ease the motherboard from its clips down the remainder of the side.
    • Exercise extreme caution when removing the motherboard as it can be fragile, and damage to it could mean the camera will become unrecoverable.
  22. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two visible ribbon cables by using the forceps.
    The manual identifies the motherboard as sy-1022. It has several surface mount fuses. Did you repair your board by replacing these fuses or swap out the board. A repair tech in the US said that when a board is swapped out and data cannot be recovered from the original board, special software is needed to get the camera operational. Did you run into that issue? Also- did you replace the board's lithium battery?
    Robert The - crwdns2934203:0crwdne2934203:0
  23. Sony a7 Shutter Replacement / Complete Disassembly, Shutter / Complete Disassembly: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly, Shutter / Complete Disassembly: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the viewfinder out ouf the housing
  24. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M 1.5x2mm screws.
    • Remove the M1.5x4mm screw.
  25. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M1.5x4mm screws.
    • Pull of the grip to the front
  26. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the grip of to the front
    이 단계(26)를 22단계 뒤에 해야 합니다. 탑을 제거하기전에 이부분을 먼저제거해야 합니다. 안그러면 flex cable이 끊어지기 쉬워요.. 아주 가늘거든요..
  27. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the top part on the sides and gently remove it to the top direction.
    写真の右上に見えているネジを外し忘れていますよ
    m.taihei - crwdns2934203:0crwdne2934203:0
  28. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M1.5x4mm self tapping and the M1.5x4mm screw.
    • Pull of the small metal plate.
  29. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cable from the ribbon connection.
    • Remove the adapter cable.
  30. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three M1.5x4mm self tapping screws.
  31. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull of the back cover. Pay attetion to the ribbon cables.
    • Remove the tripod thread.
  32. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the M1.5x2mm screw.
    • Remove the connector on the side of the camera.
    • Pull out the battery housing to the back.
  33. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M1.5x5mm screws
    • Remove the copper plate from by lifting it from the right side.
  34. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the M1.5x5mm screw.
    • Gently remove the sensor board.
  35. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the M1.5x5mm self tapping screw.
    • Remove the four small support plates.
    • Remove the front cover of the camera.
  36. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three M1.5x4mm screws.
    • Lift of the shutter assembly.
  37. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the special screw on the backside of the shutter.
  38. Sony a7 Shutter Replacement / Complete Disassembly: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the shutter curtain from the shutter drive.
    • Done :)
    How to order Sony a7 shutter drive
    GERALD RETUYA - crwdns2934203:0crwdne2934203:0
    got mine on AliExpress
    Marco -
Marco
crwdns2935283:002/25/23crwdne2935283:0
403 crwdns2915208:0crwdne2915208:0
Incomplete /slightly incorrect guide, missed some connectors on the board as in the photos they were already unplugged so it almost caused me to rip a ribbon cable.
Jaked - crwdns2934203:0crwdne2934203:0
Could you please let me know the exact step where the instructions are missing so that the missing information can be added? I hope this guide was still from value for you and that you could repair your gear!
Marco -
Very nice guide, it helped me repair my A7 locked shutter (which mechanism was blocked by a small piece of metal). On step 19 there was a small ribbon that was missing in your guide, you can see it is already removed on the top left. There were a couple more small details, but overall such fantastic help, thank you!!
Yann Coppier - crwdns2934203:0crwdne2934203:0
Found this after I done the job. Shame I did not search more. How to return count to zero after fitting the new unit? The count shows previous total, I hoped for zero to show. tia.
Simon Mountford - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 53
crwdns2936753:030crwdne2936753:0 237
crwdns2942667:0crwdne2942667:0 4,783
