This is a pre-requisite list of steps that will act as a placeholder for all other applicable guides pertaining to the Sony a7.
Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the blunt tweezers, remove the blue ribbon cable.
Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
Lift the metal plate and LCD screen away from the camera body.
Detach the amber ribbon cable from the motherboard.
crwdns2935229:09crwdne2935229:0
