Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement
  1. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Main Panels: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Main Panels: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Phillips #0 Screwdriver
    $5.49
  3. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Phillips #1 Screwdriver
    $5.49
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $5.49
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $5.49
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
  10. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $5.49
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Audio In/Audio Out Inputs: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Audio In/Audio Out Inputs: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the Audio In/Audio Out inputs on the circuit board please refer to the iFixit soldering guide to assist you.
Chao Chen
crwdns2935283:010/04/11crwdne2935283:0
82 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-35, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-35, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G35
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 4,402
