Use this guide to replace the volume and power button on your Sony Xperia ZL. You will need a plastic prying tool and a JIS #00 Screwdriver. This guide is useful if your power button stops working. It can also be used to replace the volume buttons. Make sure the phone is completely powered off before starting.
Open the small cover on the bottom of the rear cover.
Peel back the sticker under the cover to reveal two screws.
Remove the two JIS #00 screws from the back of the phone.
Remove the six screws from the phone using a JIS #00 screwdriver.
Use a nylon spudger to disconnect the seven connectors.
Peel the sticker back to get access of the connector and use a nylon spudger to disconnect it.
Remove the camera assembly using an opening tool or spudger.
Remove the motherboard with an opening tool or spudger.
Remove the battery with a plastic opening tool or spudger.
Detach the plastic covering from the top side of the phone by hand.
Pry off the signal receptor and front camera using an opening tool or spudger.
Remove the volume and power button with an opening tool or spudger.
