Sony Xperia Z5 Compact LCD Screen Assembly Replacement
Witrigs
crwdns2944107:0crwdnd2944107:0Witrigscrwdnd2944107:0crwdnd2944107:0crwdnd2944107:07crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 28, 2023crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
Wanna disassemble and change Sony Xperia Z5 Compact LCD screen assembly by yourself, following this guide.
crwdns2944105:0crwdne2944105:0
crwdns2936621:0crwdne2936621:0
  1. Sony Xperia Z5 Compact LCD Screen Assembly Replacement, LCD Screen Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement, LCD Screen Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist off 10 Phillips screws all.
    • Loosen NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove front camera.
  6. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove rear camera.
  7. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push audio jack out of the slot, no adhesive underneath.
    • Release LCD flex connector and main flex connector by flipping up the white locking tab of the connector base.
    • Separate motherboard assembly from middle housing.
  10. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The sticker underneath LCD assembly is a little bit strong, so use heat gun to soften it for a few minutes.
    • Remove LCD with digitizer assembly carefully.
  11. Sony Xperia Z5 Compact LCD Screen Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Done.
crwdns2935229:023crwdne2935229:0
Witrigs
crwdns2935283:011/24/15crwdne2935283:0
70.457 crwdns2915208:0crwdne2915208:0
crwdns2935297:0377crwdne2935297:0
crwdns2947412:018crwdne2947412:0
But what kind of glue do we need to use when we reconnect the screen and the case?
Ronen Yudzinsky - crwdns2934203:0crwdne2934203:0
screen replacement is possible without removing the back cover and logic board, similar to the Z1 compact. Simply remove the metal cover once you took the screen off to disconnect the lcd/digi cable.
Toby Liedke - crwdns2934203:0crwdne2934203:0
Yeah, I'm confused as to why everything from the back needs to be taken out, when you have to heat up the front sticker anyways and disconnect it. Seems fairly simple to just heat up, cut side adhesive, lift, unplug.
Brian Santero -
Have you done the repair that way, Toby Liedke?
jesinisterra - crwdns2934203:0crwdne2934203:0
nice guide, for my first reparation, all was fine. Thanks!
bvo - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 33,945
