Sony Xperia Z3 Compact Rear Camera Replacement
crwdns2942287:0crwdne2942287:0Use this guide to remove the rear-facing camera in your Sony Xperia Z3 Compact.
crwdns2944105:0crwdne2944105:0
Heat up along the edges of the cover to soften the glue.
Place a suction cup on the back cover and pull to open a gap.
Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
Finally, remove the back cover.
Be careful, the back cover is fragile and can break.
It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
Disconnect the NFC antenna.
Unscrew the screws holding the black midframe in place.
Remove midframe.
Disconnect the battery flex connector.
Remove rear camera bracket.
disconnect the flat top cable with a spudger
Remove rear camera
crwdns2935229:017crwdne2935229:0
Hi i just replaced myxperia z3 compact camera using your Step by step guide. ( Great job on this by the way!) but unfortunately my rear camera is still showing a black screen. What else could be causing this, either hardware or software related?
Same - however Sony seem to be aware of the issue and are not honoring warranty on the device despite being less than 2 years old which is why I am trying this.. Rather annoying. An otherwise usable phone is resigned to the parts box due to an issue with the rear facing camera.
Do I need additional adhesive to reassemble the phone, or the old one will work just fine?
You'll need a new adhesive pad.
Alternatively, use a heat pack to soften the internal glue/adhesive holding the screen.
In any case, make sure the glue/adhesive comes off nicely, otherwise you will have to spend a lot of time cleaning off glue residues before putting the new adhesive on.
axel - crwdns2934203:0crwdne2934203:0
