Sony Xperia Z2 (D6502, D6503, and D6543) - How to disassemble the phone and replace the Earpiece.
crwdns2936621:0crwdne2936621:0
Switch off the phone.
If you can't switch it off, you can use the OFF button near to the SIM card Tray.
Warm the Back Cover. You can use a hairdryer.
Use a small suction cup and plastic tools for separating the Rear panel.
Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
Should include the information about the NFC antenna.
Sounds like a dealbreaker for some people.
What about it?
Disconnect the Battery Flex Cable and remove the two Philips screws.
Li-Polymer Battery, 3.8V, 3200mAh
Part number: LIS1543ERPC
Did you use the custom adhesive or the 3M double sided tape?
Disconnect one by one:
Magnetic Charging Dock Flex Cable
Volume / Power Button and Microphone Flex Cable
Main Camera
Audio Jack and Light Sensor Flex cable
Coaxial Antenna Cable
I know it should probably be obvious, but just make sure you’ve removed any MicroSD card and the SIM card tray before trying to lift out the board, as otherwise they’ll prevent it from lifting :)
Also, I had to peel off one side of the strip of black tape at the top right (visible in the photos, but not mentioned)
Took the Logic Board, making it pick up first on the left side
Earpiece
Part Number: VWRS087 / ZVRS087
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
I accidentally torn apart one of the cables( vibrate cable:the brown one) I'm messed up! Vibration not working. What can I do? Where can I buy one of those cables? Please reply!
