If your Sony Xperia Z1 phone is taking blurry photos or failing to focus, use this guide to replace the rear camera module.
The rear camera captures high-resolution photos and videos. A faulty rear camera may result in image distortion, camera app errors, or complete camera failure. Before using this guide, visit the Sony Xperia Z1 Troubleshooting Page to confirm the rear camera is the source of the problem.
This guide involves removing the rear glass panel, which may shatter if already cracked. Be cautious of sharp edges and wear safety protection as needed. You may also need to use a heat gun to soften the adhesive before removing the rear glass. Follow this guide for tips on using a heat gun safely.
Before starting, power off your phone completely and disconnect it from any external power source.
With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
Using the plastic opening tool, carefully pry off the flex connector beside the camera housing.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to pull the camera out of the top left corner of the phone.
