Sony Xperia Z1 Compact Screen Replacement
crwdns2944105:0crwdne2944105:0
When the glue is warm slowly start prying from the top corner.
If the glue is cooled down heat more. Don't force it.
Remove the data cable from the phones body.
Test if the new screen works properly.
If the screen works, remove the new screen and add the double sided tape
Connect the new screen to the phone.
Now push town not to tight not to softly to the screen.
And that's it. You finished the screen replacement.
crwdns2935229:030crwdne2935229:0
crwdns2947412:05crwdne2947412:0
There is a very good Youtube video of this. I think these are screenshots from it.
Good video! Help me too! Thanks
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
