Sony Xperia Z Ultra Front Camera Replacement
crwdns2869540:0crwdne2869540:0: 2775
9
31
105
2,775
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 8 crwdns2931279:0crwdne2931279:0
If your screen went black while using the front camera and performing a hard reset and software update did not fix this problem, replacing the front camera may solve these problems.
    1. Sony Xperia Z Ultra Front Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the small suction cup to lift the back panel:
      • Press the small suction cup on to the middle of the back panel.
    2. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
      • While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
      • Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
    3. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back panel by pulling the small suction cup upwards.
    4. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following six screws with a Phillips #000 screwdriver:
      • five silver 2.1 mm screws
      • one gold 3.1 mm screw
    5. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
    6. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use care to remove the motherboard shield, as it may break. The motherboard shield is made of a very thin plastic.
      • Remove the motherboard shield by lifting the lower end upwards first.
    7. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Detach the battery connection cable by prying it upward with the spudger.
    8. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry the upper end of the antenna upwards with the spudger.
    9. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Detach the antenna by pulling the upper end upwards and outwards.
    10. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
    11. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the phone.
    1. Sony Xperia Z Ultra Front Camera Replacement, Front Camera: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use care to pry the front camera off, as it can easily be damaged if too much force is used. The connection from the front facing camera to the motherboard is delicate.
      • Pry the connection upwards from the motherboard with the spudger to reveal the front facing camera.
    2. Sony Xperia Z Ultra Front Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the front facing camera by pulling upward on the flap to its right .
Aaron Quinn
crwdns2935283:010/01/15crwdne2935283:0
930 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-6, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 4-6, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S4G6
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 105
crwdns2959996:0crwdne2959996:0 2,775
