Sony Xperia XZ2 Vibration Motor Replacement
  1. Sony Xperia XZ2 Vibration Motor Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the connector by using a spudger to pop it off.
  6. Sony Xperia XZ2 Vibration Motor Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
    • Remove the one 3 mm Phillips #00 screws.
    • Remove the two 1mm Phillips #00 screws.
    • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
  7. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the metal screen shield out of the phone.
  8. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to pry up the battery flex connector to pop the battery out.
  9. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the phone.
  10. Sony Xperia XZ2 Vibration Motor Replacement, Vibration Motor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XZ2 Vibration Motor Replacement, Vibration Motor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.5mm head screws with a Phillips #00 screwdriver.
  11. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the vibration flex connector by inserting a spudger into the socket and gently prying off the connector.
  12. Sony Xperia XZ2 Vibration Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the vibration motor from the device.
Matthew Ionescu
crwdns2935283:001/24/19crwdne2935283:0
424 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G5, White Winter 2019 crwdns2935289:0Cal Poly, Team S19-G5, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S19G5
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,685
