If your phone is running slow or looses charge very quickly, your battery might be the reason and it may be time for a replacement. This guide will instruct you on replacing the battery of your Sony Xperia XZ2.
Before removing the battery, you will have to remove the front screen. You will need a spudger and a Phillips #00 screwdriver head.
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
Gently remove the connector by using a spudger to pop it off.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
Lift the metal screen shield out of the phone.
Use the spudger to pry up the battery flex connector to pop the battery out.
لقد كان العمل على هذا الهاتف مريحا جدا و جميل
Mouad Driouch - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
