crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Use a hair dryer to heat each corner of the phone.
Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
Consider saying “loosen” instead of “soften” so that steps 2 and 3 use the same terms. Somebody may not know that heating the glue will loosen it, and so they will be confused reading “once the adhesive is loosened” in step 3.
Press a suction cup on a heated corner of the device.
Hold the phone down and gently lift the suction cup to create a small gap.
sure that there is adhesive tape on backcover?
where should it tape on at the device inside?
looks more like only plugged together`?
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99-
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Slide your plastic card along the side of your phone to loosen the adhesive.
Move the card along the sides of the phone to lift all of the corners.
Lift up the back cover by lifting up the sides of the phone with your hand.
Peel off the two pieces of black tape covering the battery with your hands.
Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
Grammar, consider rewording. “Use the iFixit Opening Tool to remove the flexible orange strip which is connected to the battery from the motherboard” or “Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard” or another alternative depending on your intended meaning.
exelente, a melhor aula de celular que eu vi.
Wedge the iFixit Opening Tool underneath the battery.
Remove the battery by pulling up on the iFixit Opening Tool.
crwdns2935229:012crwdne2935229:0
magnificent…i successfully change a new battery for xperia xa1 ultra…its not the time yet for this xperia to retire from service to me…thank you very much
Wher did you get the batterry from? And is it good as the original?
Where can I get the original battery
How do you remove it? (Seems obvious but write for any audience, and say how to do things instead of just what to do)
Kyle Ladtkow - crwdns2934203:0crwdne2934203:0
