Sony Xperia XA1 USB-C Module Replacement
    1. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
      • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
      • Do not apply heat in one area for too long.
    1. Sony Xperia XA1 USB-C Module Replacement, Speaker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement, Speaker: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement, Speaker: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to lift the battery connector.
      • Lift the flaps on both sides of the battery.
    2. Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pinch the pull tab at the bottom of the battery.
      • Gently lift the battery out.
      • Handle the battery with caution. It is very fragile.
    3. Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
    4. Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
      • Once the piece is loose, use your hand to remove the speaker from the phone.
    1. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
      • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
    2. Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA1 USB-C Module Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
      • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
sebastianh034
crwdns2935283:002/14/23crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-4, McMurrin Spring 2023 crwdns2935289:0Utah Tech University, Team 1-4, McMurrin Spring 2023crwdne2935289:0
UTAHTECH-MCMURRIN-S23S1G4
crwdns2935297:084crwdne2935297:0
thanks a lot, super clear, done everything in ~10 minutes
Eugene - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 864
