Sony Xperia XA Battery Replacement
  1. Sony Xperia XA Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the RAF antenna.
  7. Sony Xperia XA Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia XA Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia XA Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia XA Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out with your hands.
crwdns2935229:011crwdne2935229:0
Cassidy Davis
crwdns2935283:004/18/18crwdne2935283:0
645 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G2, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S17-G2, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S17G2
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Mike Jurkiewicz - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,503
