Sony Xperia TL Display Assembly Replacement
    1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool to pry the top plastic section off.
    2. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to pry the bottom plastic section off.
    3. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 5mm screws.
      • Use the plastic opening tool to pry off the back.
    1. Sony Xperia TL Display Assembly Replacement, Loud Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Loud Speaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Loud Speaker: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool to remove the loud speaker module.
    1. Sony Xperia TL Display Assembly Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool to detach the ribbon running across the battery.
      • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
    1. Sony Xperia TL Display Assembly Replacement, Battery Harness: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Battery Harness: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Battery Harness: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unhook the 2 connections between the harness and phone shell.
      • Using the plastic opening tool, pry the harness up and remove it.
      • There is an adhesive on the bottom half of the battery harness.
    2. Sony Xperia TL Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The final step is taking the entire harness off of the phone.
    1. Sony Xperia TL Display Assembly Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia TL Display Assembly Replacement, Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the Phillips #00 to remove the 3 5mm screws.
      • Lift the plastic cover off.
      • Use the plastic opening tool to pry the motherboard out of the phone shell.
    1. Sony Xperia TL Display Assembly Replacement, Ear Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the plastic opening tool to detach the ear piece speaker.
      • Avoid majorly bending the tiny metal hooks holding the ear piece in.
    1. Sony Xperia TL Display Assembly Replacement, Display Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
Adam Giniger
crwdns2935283:009/22/14crwdne2935283:0
1,303 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-4, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 4-4, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S4G4
crwdns2935297:0120crwdne2935297:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 102
crwdns2942667:0crwdne2942667:0 1,037
