This guide can be used to replace the headphone jack.
Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
