The Sony Xperia M4 Aqua has an internal battery, meaning replacement requires phone disassembly.
Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
Remove the battery once all of the adhesive is broken, and the connector is unplugged.
crwdns2935229:017crwdne2935229:0
crwdns2947412:011crwdne2947412:0
Hi... do you need to add some adhesive to reassemble it? Thanks.
U actually buy another back end cover that has the adhesive....
I found that I could just push it back on with the original glue and it reattached ok.
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Good video thanks.
I'm currently living in Thailand and they don't fix Sonys here in Krabi so I need to do it myself. Lazada has got the lcd and back cover for me, but they don't have a battery. I have a Sony Xperia aqua m4. Will the z3 battery fit...
