E2104, E2105, E2115, E2124
How to disassemble, take apart the device and change / replace broken touch screen glass digitizer, LCD
crwdns2936621:0crwdne2936621:0
Remove the back cover and any installed SIM and memory cards.
There are 8x black screws Torx T4. Remove them.
Remove the small black rubber at the lower left corner.
Under it is the battery flex cable, disconnect it.
Use a plastic tool to separate the middle frame.
The battery is glued to the middle frame with an adhesive tape.
Loudspeaker
Disconnect the touch screen flex cable.
Under it is the LCD flex cable. Disconnect it also.
Cover the glass with a scotch tape.
Warm the glass for about minute.
With a cutter lift a little the glase to make a room for the plastic tool.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Carefully put the plastic tool between the glass and the LCD.
Remove the display frame.
Install adhesive tape.
Start with the reassembling.
crwdns2935229:012crwdne2935229:0
Grazie! È stato davvero utilissimo. :)
Doesn't the original glass and digitalizer come out with its biadesive?
First Timer here:
I've followed this and replaced the cracked screen (the clear bit).
But it still looks cracked; could it be that I have a cracked LCD thingy as well? (is that the black bit?).
If so what's the part number for that?
Why don't you just buy the screen which has the lcd and digitiser already assembled? That will save you a lot of hassle for only a few £'s more :)
