Sony Xperia E3 Touch Screen Replacement
crwdns2936621:0crwdne2936621:0
  1. Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the device
    • Remove the SIM and the memory cards.
    • Remove 4x rubber corners.
    • There are 6x black screws Torx T4, remove them.
  2. Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic tool and separate the rear bezel.
    • Be careful for the side buttons.
  3. Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the touch screen flex cable.
    • Disconnect the battery flex cable.
  4. Sony Xperia E3 Touch Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a hair dryer or heat gun warm the glass, at first for about 2-3 minutes.
    • Use a thin plastic tool, like a plastic pick and start the separation from the underside.
    • Do this very slow and periodically warm the glass!
    • At the beginning you have to separate the touch screen glass from the main frame.
  5. Sony Xperia E3 Touch Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Now continue with a plastic card.
    • AGAIN!!! Very slowly and periodically worm the glass.
    • The LCD is thin less than a millimeter!
    • Remove the touch screen.
  6. Sony Xperia E3 Touch Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now is time to test the phone.
    • If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD
    • With a plastic pick gently scrape the glue.
    • With a cloth and isopropyl alcohol clean the LCD.
    • Don't use a lot of alcohol. if the liquid passes behind the LCD, will appear spots that you can't remove.
  7. Sony Xperia E3 Touch Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Xperia E3 Touch Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the new touch screen or on the main frame put adhesive sticker 3mm.
    • Be careful not to cover the the places for the camera, sensor, earpiece, etc.
    • Lift the logic board a little bit, so that the touch screen flex cable can pass.
    • It's easier if you can order the touch screen together with adhesive which is cut off specifically for model.
  8. Sony Xperia E3 Touch Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassemble the device.
    • That's all.
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194 598 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01 702crwdne2935297:0
crwdns2942667:0crwdne2942667:0 8,085
