Sony XAV-AX100 Volume Knob Replacement
  1. Sony XAV-AX100 Volume Knob Replacement, USB Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement, USB Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement, USB Cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Volume Knob Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Volume Knob Replacement, Display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  10. Sony XAV-AX100 Volume Knob Replacement, Display Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement, Display Board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement, Display Board: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  11. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  12. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  13. Sony XAV-AX100 Volume Knob Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to remove the display board from the radio.
  14. Sony XAV-AX100 Volume Knob Replacement, Volume Knob: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement, Volume Knob: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony XAV-AX100 Volume Knob Replacement, Volume Knob: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the silver knob cover by pulling upwards on it.
    • Remove the plastic face plate.
    • Pull off the black knob.
Abdulaziz Redha
crwdns2935283:002/22/18crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G5, Cagle Spring 2018 crwdns2935289:0USF Tampa, Team S1-G5, Cagle Spring 2018crwdne2935289:0
USFT-CAGLE-S18S1G5
crwdns2942667:0crwdne2942667:0 3,102
