This tutorial will guide you in replacing the LCD display and cover.
Remove the two black 6.4mm Phillips screws from the back of the device.
Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
Remove the two 2.8 mm phillips screws located on either side of the device near the top.
Carefully pull the top piece away from the device.
Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
Lift up on and remove the Bluetooth module.
Remove the two 2.8mm silver Phillips screws on the sides of the frame.
Insert a plastic prying tool between the bottom of the case and the motherboard.
Pry up the assembly and lift it away from the case.
Remove the yellow tape from the battery and volume control module.
Use a prying tool to pry under the volume control module.
Remove the tape from EMF shield and the LCD housing.
Lift up on the volume control ribbon.
Insert a plastic opening tool under the battery and lift up to remove it.
Remove the black shielding tape from above the Hard Drive.
Peel the foam cover away from the hard drive.
Use a plastic opening tool to remove the EMF chip from the motherboard.
Remove the plastic bracket by pushing up with your thumb to expose the display connection.
Use the flat end of a spudger to flip up the retaining flap on the audio jack module.
Peel back the ribbon for the audio jack and remove the 1.8mm silver Phillips screw.
Remove the mic casing by pushing up and in.
Remove the headphone jack and the bottom casing.
Use the prying tool to remove the LCD ribbon wire.
Lift up on the LCD ribbon and remove the two 1.8mm silver Phillips screws.
Lift the motherboard away from the frame with your thumb to remove it from the device.
Pull the volume control module through the space in the frame.
To remove the LCD display cover, first melt the glue with the iOpener tool.
For more detailed instructions on how to use the iOpener, see iOpener Instructions
Carefully slide the iOpener wedge tool under the edge of the LCD display cover to separate it from the device.
Slide the wedge under all edges of the cover.
Once all of the glue has been broken, you can pull up on the cover to remove it.
The flat side of the spudger tool also works for this step
Remove the two 1.8 mm Phillips screws from both sides of the frame.
Use a strong pry tool to lift the metal brackets away from the device. You will need to bend the metal slightly to remove it from the dimples.
Once separated, pull the innermost frame containing the LCD display away from the brackets.
Slide an opening pick under the LCD display to separate it from the rest of the device.
Lift the LCD display off of the frame to remove it from the device.
