Sony Walkman NWZ-E438 USB Port Replacement
  1. Sony Walkman NWZ-E438 USB Port Replacement, Disassembling Sony Walkman NWZ-E438: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Walkman NWZ-E438 USB Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the circuit board from the device.
  7. Sony Walkman NWZ-E438 USB Port Replacement, USB Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using fine point tweezers, push them between the chip and USB port.
  8. Sony Walkman NWZ-E438 USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly pry the USB port off of the chip.
    • You will need to solder the new USB onto the circuit board.
  9. Sony Walkman NWZ-E438 USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove USB port.
Cheryl Zinn
crwdns2935283:010/08/15crwdne2935283:0
525 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-5, Plummer Fall 2015 crwdns2935289:0Eastern Washington University, Team 2-5, Plummer Fall 2015crwdne2935289:0
EWU-PLUMMER-F15S2G5
Wher buy new port????pavel87cz@gmail.com
Pavel Drobny - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 777
