Sony WH-XB910N Headphone Cushions Replacement
  1. Sony WH-XB910N Headphone Cushions Replacement, Headphone Cushions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement, Headphone Cushions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement, Headphone Cushions: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the prying tool between the left cushion and the plastic.
    • This guide will be starting with the left side of the headphones, but the order doesn’t really matter.
    • Pry the cushion apart from the plastic. You will hear a small click as the cushions become unclipped.
    • Work your way around the cushion until the cushion is completely detached.
    • There will be some bumps around the lining that may prevent you from sliding the prying tool around the cushion. Do not force your way through them; instead re-insert the tool past the point and work from there.
  2. Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step with the right side cushion.
    • Insert the prying tool and use it to unclip the cushion.
  3. Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Line the tabs on the replacement cushion up with the slots in the left side of the headphones.
    • Both the replacement cushions are the same, so don’t worry about trying to figure out which one is which.
    • Place the cushion, making sure to keep the tabs lined up.
  4. Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push down on the cushions to connect them into place.
    • Make sure to apply pressure around the whole cushion.
    • You should hear clicks when it connects.
  5. Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat steps 3 and 4 for the right cushion, again making sure to apply pressure around the entire cushion.
  6. Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-XB910N Headphone Cushions Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lightly tug on the cushions to make sure that they’re secure.
    • Don’t pull too hard; if any of the tabs didn’t connect it will be obvious (see the second picture).
    • Make sure to check both the left and right side, and to check the entire cushion.
    • If anywhere isn’t secure, push down on it again like in Step 5.
    • Once both replacement cushions are secure, the fix is complete.
Having completed this replacement you can now continuing listening to your favorite music with the Sony WH-XB910N Headphones.
Shannon Forsberg
crwdns2935283:010/03/24crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
University of Wisconsin Eau Claire, Team 1-7, Cameron Fall 2024 crwdns2935289:0University of Wisconsin Eau Claire, Team 1-7, Cameron Fall 2024crwdne2935289:0
UWEC-CAMERON-F24S1G7
Instructions are perfect.
My prying tool was a little triangle but it worked just as well.
Razzler - crwdns2934203:0crwdne2934203:0
Are there instructions and parts source for doing the headband cover? These seem to break down too.
ronjobmann - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 457
