This repair guide will detail how to replace the speakers on the Sony WH-CH720. This repair guide uses the right speaker, but the process is the same for both sides. This is necessary in the event the speakers stop working entirely or the audio begins cutting out when using the headphones.
Take caution in using the soldering iron and heat gun. Ensure the device is powered off for safety.
Place the headphones down on a table, and orient them in this way.
Remove the earmuff.
Check introductions to ensure you remove the correct side earmuff for each repair guide!
Remove the four 5 mm screws holding the speaker housing onto the headphones.
Move the now detached speaker housing to the side, being careful of the wires.
On the backside of the speaker housing, remove the four 3 mm screws to detach the panel.
With the speaker panel removed, desolder the wires connecting the speaker.
Use a heat gun to loosen the glue around the speaker inside the housing.
Finally, take the metal prying tool, and carefully remove the speaker.
