Sony WH-CH520 Speaker Driver Replacement
  1. Sony WH-CH520 Speaker Driver Replacement, Speaker Driver: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-CH520 Speaker Driver Replacement, Speaker Driver: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-CH520 Speaker Driver Replacement, Speaker Driver: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay headphones flat against the surface with the ear cushions oriented upwards.
    • Pinch the cushion near the edge of the device to carefully pull the cushion off.
  2. Sony WH-CH520 Speaker Driver Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-CH520 Speaker Driver Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 2.5 mm screws from the headphones using a JIS #00 screwdriver.
  3. Sony WH-CH520 Speaker Driver Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-CH520 Speaker Driver Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-CH520 Speaker Driver Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place one end of an opening tool against the edge of the base with the hook-like side pushing up against the covering.
    • Carefully pull the tool down against the edge to lift the covering.
    • Move the tool to different spots around the base of the headphones to pry it up until the covering comes off.
  4. Sony WH-CH520 Speaker Driver Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-CH520 Speaker Driver Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to desolder the two connections where the exposed wires meet the speaker contact.
    • Pull the wire away from the speaker to remove it while the solder melts. Do this for both wires.
    • Disconnect the wires from the speaker driver, and you will be able to replace the old driver with the new one using the same wires.
Harry Jones
crwdns2935283:010/18/24crwdne2935283:0
293 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Konn Fall 2024 crwdns2935289:0UMass Dartmouth, Team 2-2, Konn Fall 2024crwdne2935289:0
UMASSD-KONN-F24S2G2
Where do I get replacement speakers though
Victor Ohiovbeunu - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 505
