Are the earpad cushions of your Sony WH-CH520 headphones worn out, loose, or damaged? This tends to happen as typically wear and tear takes place on most headphones over time. If so, follow this guide to remove the old earpad cushion and replace it with a new cushion.
Hold the headphones in one hand, and with your other hand lightly pinch the earpad cushion.
Pull the pinched portion of the cushion up and towards yourself.
Pull part of the cushion off of the lip of the headphones.
Fully remove by pulling the earpad cushion down and away from yourself.
