Sony WH-1000XM3 Earpad Foam Screens Replacement
  1. Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove earcup cushions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove earcup cushions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove earcup cushions: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before beginning, turn off the headphones
    • For more information, see Sony WH-1000XM3 Earcup Cushion Replacement
    • Insert a plastic spudger between the cushion and the earcup frame
    • There are six clips that hold the cushion in place, release them moving the spudger around the frame
  2. Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove old foam screens: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove old foam screens: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull away right and lef foam screen
    • Screens are made by three pieces glued together, leverage on the ones glued to the earpad to avoid damaging the old screens (you will need them as reference for the tape placement)
  3. Sony WH-1000XM3 Earpad Foam Screens Replacement, Prepare new screens: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut double-sided tape and place it in the same position of the old screens
    • Right and left screens are not identical and have different tape placement
  4. Sony WH-1000XM3 Earpad Foam Screens Replacement, Install new screens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove tape cover and place new screens in position
    • In the right earcup there is a hole (in red), DO NOT COVER IT with the screen
Once installed the new screens, reinstall earpad
dinoo_fixit
crwdns2935283:003/22/22crwdne2935283:0
1,419 crwdns2915208:0crwdne2915208:0
Danke! / Thank you!
Ich frage mich nur warum der Schaumstoff die Öffnung (Bild 4) nicht verschließen sollte (reines Interesse)? Hat das eine Auswirkung auf die Funktion des NC? /
I just wonder why the foam should not close the opening (picture 4) (just out of interest)? Does this affect the function of the NC?
S S - crwdns2934203:0crwdne2934203:0
Yes, as far as I understood it is necessary for NC and pressure equalization maybe
dinoo_fixit -
crwdns2936753:030crwdne2936753:0 171
crwdns2942667:0crwdne2942667:0 2,945
