Sony Vaio VPCW211AX RAM Replacement
  1. Sony Vaio VPCW211AX RAM  Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with the laptop face up on a flat surface.
  2. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop with the keyboard facing you.
  3. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  4. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
  5. Sony Vaio VPCW211AX RAM  Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips #0 screwdriver to remove the 7 top case screws.
  6. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, pry open at the seams.
    • Open the gray top of the laptop from the base black portion.
    • Slide the spudger along the seam, and then carefully open the top.
  7. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the top carefully without disconnecting the two parts.
    • Be mindful and careful of the ribbon cable attaching the two parts together.
  8. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture.
  9. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After that step, the RAM should pop up on its own as shown in the picture.
  10. Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VPCW211AX RAM  Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully press the sides near the right edge of the part and remove it from it's base.
Giselle Dougan
crwdns2935283:001/31/18crwdne2935283:0
760 crwdns2915208:0crwdne2915208:0
I have a 21212L and you have to remove the screws under the flap to remove the keyboard firstm you also do not have to remove the top assembly at all.
Samuel Gottschall - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 884
