If typing on your Sony Vaio VPCCB290X keyboard has become more challenging or stopped working entirely, you might need to replace the keyboard.
Before beginning the keyboard replacement, take some time to watch How to Set Up Your Anti-Static Mat and Wristband. This will prevent electrostatic discharge, which can be dangerous and damage parts of the laptop.
After gathering and familiarizing yourself with the necessary tools, learn how to replace a non-functioning keyboard below.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.16
Attach an anti-static wrist strap to a piece of metal to prevent possible short circuiting.
Use a spudger to press in the black clips that lock the keyboard in place.
As you press in the black clips, remove the screws near the motherboard using the screwdriver.
Using the metal spudger, pick a corner and carefully begin to pop off the keyboard.
Unplug the thin cable by just simply pulling the cable straight out of the connector.
To fully release the old keyboard, lift the black wedge clip by using the spudger tool to press down on the clip and release the wider cable.
