Sony Vaio VGN-Z48GD SSDs Replacement
  1. Sony Vaio VGN-Z48GD SSDs Replacement, SSDs: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your laptop before starting.
    • Disconnect all external cables from the device.
  2. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over so that the battery is facing away from you.
    • Unlock the battery by using your finger to push the "Lock" latch to the right.
    • You will hear a soft click when the latch has been disengaged.
  3. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your finger on the "Release" latch.
    • Slide the latch to the right and hold it.
    • Use your other hand to lift the battery from the groove.
    • Remove the battery.
  4. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove a 5 mm Phillips #000 screw from the RAM cover located in the centre of the device.
    • Remove the RAM cover.
    • There is no need to remove the RAMs as they won't get in the way.
  5. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following eleven screws:
    • Five 13 mm Phillips #000 screws
    • Six 5 mm Phillips #000 screws
  6. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device and open the lid so that the keyboard is facing upwards.
    • Use an opening tool to lift the keyboard assembly slightly.
    • Make sure you don't lift the keyboard assembly too much as there is a ribbon cable in between.
  7. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the keyboard assembly towards you.
  8. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry the keyboard assembly connector up from its socket on the motherboard.
    • Remove the keyboard assembly.
  9. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry the uSATA ribbon cable connector up from its socket on the motherboard.
  10. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 13 mm screws from the SSD bracket using a Phillips #000 screwdriver.
    • Remove the SSD bracket.
  11. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the SSD bracket.
    • Use your hand to disconnect the uSATA connector on the right.
  12. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hand to disconnect the uSATA connector on the left.
    • Remove the uSATA ribbon cable.
  13. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 2 mm Phillips #00 screws.
  14. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  15. Sony Vaio VGN-Z48GD SSDs Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the SSDs from the bracket.
Vincent L
crwdns2935283:001/10/19crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
York University, Team S3-G51, Melo-Thaiss Fall 2020 crwdns2935289:0York University, Team S3-G51, Melo-Thaiss Fall 2020crwdne2935289:0
YORK-MELO-THAISS-F20S3G51
crwdns2942667:0crwdne2942667:0 1,318
