Sony Vaio VGN-S260 Ethernet Ports Replacement
  1. Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Ethernet Ports Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Ethernet Ports Replacement, Upper Casing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Ethernet Ports Replacement, Optical Drive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw holding the optical drive casing to the logic board.
  13. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws holding the optical drive to the logic board.
  15. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  16. Sony Vaio VGN-S260 Ethernet Ports Replacement, Ethernet Ports: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement, Ethernet Ports: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blue ribbon from the Ethernet Circuit Board.
  17. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws near the Ethernet Port circuit board.
  18. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws for the second ethernet circuit board.
  19. Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio VGN-S260 Ethernet Ports Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ethernet ports.
Jeffrey Bryan
crwdns2935283:004/20/10crwdne2935283:0
570 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Cal Poly, Team 16-4, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 16-4, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S16G4
crwdns2935297:030crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,695
