The processor can be replaced with an identical or compatible processor. Please double check to see if the new processor is compatible with this laptop.
Power off the laptop.
Unplug the charging cable and any other cables plugged into the laptop.
Turn the laptop over so that the back panel is facing upwards.
Locate two switches above the battery that lock it into place.
Push the left-hand switch, that says "lock" above it, so that it is unlocked.
Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
Grip the cover of the optical drive and slide it out.
Remove all the 8mm Phillips #1 screws on the backside of the laptop.
There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
There are three 3mm screws under the optical drives that also need to be taken out.
Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
Pry along the edges of the back panel using the spudger.
Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
Locate and remove the four 3mm Phillips #1 screws above the processor and attached to the bronze heat-pipes.
Gently lift up the fan and heatsink from the the laptop.
The fan attached onto the heat sink with electrical tape. Removing the electrical tape allows you to replace the fan.
Locate the locking mechanism for the processor.
Using a flathead screwdriver, rotate the mechanism to the unlocked position.
Gently lift up the processor with two fingers on each end.
To reassemble your device, follow these instructions in reverse order. In addition, please remember to remove and replace the old thermal paste. For instructions, please refer to this guide.
