Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal
  1. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  4. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Optical Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  5. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
  6. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Back Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Back Panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Back Panel: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
    • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
    • There are three 3mm screws under the optical drives that also need to be taken out.
    • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
  7. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry along the edges of the back panel using the spudger.
    • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
Sid
crwdns2935283:005/18/14crwdne2935283:0
314 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-17, Regan Spring 2014 crwdns2935289:0Cal Poly, Team 9-17, Regan Spring 2014crwdne2935289:0
CPSU-REGAN-S14S9G17
crwdns2935297:018crwdne2935297:0
I put it back in the correct order but my screen won’t turn on.
zakikhimani - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,814
