This guide will show you how to replace the hard drive in your Sony Vaio VGN-FS640 laptop.
Lay the closed laptop on its screen so the bottom is facing towards you.
Push both latches towards the center of the battery.
Revome the battery by pushing it away from the laptop.
Set the battery away from the laptop.
Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
Slide the cover until it is free from the laptop case.
Lift the cover to remove.
Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
The Hard Drive should now be disconnected.
Lift the drive out with the tab on the tray.
cant sign to recover my external hard drive
