Sony Vaio Tap 11 Power Jack Replacement
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the cable and jack assembly.
Alexander Bridges
crwdns2935283:009/16/15crwdne2935283:0
1,217 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Fall 2015 crwdns2935289:0IUPUI, Team 1-2, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S1G2
crwdns2935297:020crwdne2935297:0
I wonder if you have the part number or can supply this power jack?
James Toal - crwdns2934203:0crwdne2934203:0
Yes, Where can I find this replacement part?
mikebeard65 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,030
