Sony Vaio SVS151190X Disk Reader Replacement
  1. Sony Vaio SVS151190X Disk Reader Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #1 Phillips screwdriver, remove the two 5mm screws as directed.
    • Slide off the back cover.
    • Ensure different sized screws are kept separate during disassembly.
  2. Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3mm screws using the Phillips #1 screwdriver.
  3. Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the hard drive and unplug the orange ribbon wire.
  4. Sony Vaio SVS151190X Disk Reader Replacement, Disk Reader: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To loosen the keyboard, remove the twenty 5mm screws using the Phillips #1 screwdriver.
  5. Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over and open it up.
    • Using a plastic opening tool and opening picks, pry off the keyboard from the bottom cover. Start from one of the corners of the device and work your way around.
    • The bottom cover is somewhat fragile, do not be too forceful when prying off the keyboard.
  6. Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The ribbon wire that attaches the keyboard and bottom cover is fragile, take care during removal.
    • Remove the keyboard from the bottom cover and place it down as demonstrated.
    • Carefully pull the plastic tab and remove the ribbon wire.
  7. Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly pull up the black tape covering the disk drive's ribbon wire.
    • Pull up the blue plastic strip attached to the ribbon wire and remove the ribbon wire from the port.
    • Detach the ribbon wire from the fan so the disk reader can be removed.
  8. Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm screws using the Phillips #1 screwdriver.
  9. Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio SVS151190X Disk Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the black plastic covering.
    • Remove the disk reader.
Jacob Bellows
crwdns2935283:001/14/20crwdne2935283:0
277 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S1-G2, Cromer Twal Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S1-G2, Cromer Twal Spring 2020crwdne2935289:0
ERAU-CROMER TWAL-S20S1G2
crwdns2942667:0crwdne2942667:0 822
