The battery in the Sony Vaio SVF15A16CXB laptop stores power for the laptop to use while on.
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Using a plastic opening tool, pull the optical drive out of the computer by the seam.
Run the opening tool along the bottom cover seam.
Lift the clip marked in red in order to release the back cover.
Lift the back cover.
Unscrew the four 6mm screws with the Phillips #0 screwdriver.
Lift the battery and remove it from the laptop.
