This guide helps users to remove the back panel, which is required to access the other pieces of the laptop and is the first step to any part replacement.
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Using a plastic opening tool, pull the optical drive out of the computer by the seam.
Run the opening tool along the bottom cover seam.
Lift the clip marked in red in order to release the back cover.
Lift the back cover.
