Sony Vaio SVE171C11L Display Replacement
  1. Sony Vaio SVE171C11L Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery away.
  5. Sony Vaio SVE171C11L Display Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
  6. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio SVE171C11L Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the screw have been removed, pop the hard drive cover open.
  7. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 3 screws that secure the hard drive.
  8. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When finished removing the screws, use your fingers to hold the blue ribbon attached from the hard drive to remove it from laptop
  9. Sony Vaio SVE171C11L Display Replacement, Display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two hinges that connect the display to the body of the laptop
    • Unscrew two 9mm screws and two 4mm screws that are on both hinges.
  10. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display cable by pulling upward.
  11. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display from the bottom of the laptop.
  12. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio SVE171C11L Display Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5mm screws on the corners of the display case.
  13. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pick around the case to help detach them.
  14. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio SVE171C11L Display Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 2mm screws that are on each hinge.
  15. Sony Vaio SVE171C11L Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display from its case.
Edward Briseno
crwdns2935283:009/26/22crwdne2935283:0
896 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 6-3, Adachi Fall 2022 crwdns2935289:0CSU Los Angeles, Team 6-3, Adachi Fall 2022crwdne2935289:0
CSULA-ADACHI-F22S6G3
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 458
