This is a comprehensive guide to replace the Sony Vaio SVE151G11L display.
Flip laptop over so the bottom is facing upwards.
Remove bottom of laptop.
Remove antenna wires attached to the WiFi card using a plastic opening tool.
Remove the display cable by pulling upwards.
Remove the power display cable with a plastic opening tool by pushing outwards.
Remove 4 hinge screws with a Phillips #0 screwdriver.
Lift upward on the hinges with a plastic opening tool to release them.
Separate the bottom of the laptop from the monitor.
Completely detach screen from the laptop.
