Sony Vaio PCG-TR3A Teardown
crwdns2931587:0crwdne2931587:0
  1. Sony Vaio PCG-TR3A Teardown, Removing The Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-TR3A Teardown, Removing The Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-TR3A Teardown, Removing The Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the power cable before removing the battery.
    • Slide the 2 sliders on the under side of the laptop to the unlock position, as shown.
    • Grasp the battery and tilt it out at an angle - not straight out.
  2. Sony Vaio PCG-TR3A Teardown, Removing Memory Cover/Replacing RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-TR3A Teardown, Removing Memory Cover/Replacing RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the pictured screwed holding the memory cover in place.
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory sticks, push both metal pieces holding them in place outwards, and the sticks will pop up. -picture of RAM inside -
    • Pull the sticks out carefully. - Picture of the RAM stick -
    • Using a small spudger, pry up the two rubber feet to reveal the screw holes underneath.
  3. Sony Vaio PCG-TR3A Teardown, Removing Rear Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the rest of the screws on the underside of the PCG-TR3A.
    • Note: for ease of reassembly, keep track of which screws go where.
  4. Sony Vaio PCG-TR3A Teardown, Removing Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-TR3A Teardown, Removing Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open the display carefully - the keyboard and bezel will be loose.
    • Lift the keyboard away from the top carefully.
    • **WARNING** The keyboard has a connector to the motherboard. Disconnect this before completely removing it.
  5. Sony Vaio PCG-TR3A Teardown, Removing Trackpad and Palm Rest: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-TR3A Teardown, Removing Trackpad and Palm Rest: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one screw holding the top assembly on.
    • Unplug the trackpad connector from the board.
    • Maneuver the palm rest away from the bottom half of the machine. Both the palm rest and trackpad will come off together.
  6. Sony Vaio PCG-TR3A Teardown, Removing Hard Drive and Optical Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws holding the hard drive and optical drive in place.
    • Lift up on the connectors connecting the drives to the board and lift the drives up to remove them.
  7. Sony Vaio PCG-TR3A Teardown, Removing Wi-Fi Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
    • Carefully pull it out.
  8. Sony Vaio PCG-TR3A Teardown, Removing The Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-TR3A Teardown, Removing The Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-TR3A Teardown, Removing The Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three screws holding the board in place.
    • Disconnect the ribbon cables connecting the daughterboards to the motherboard and the large connector in the middle of the board.
    • Lift up the board gently. There will be two connectors on the underside of the board. Disconnect them before completely removing the board.
crwdns2935103:0crwdne2935103:0
Kobi
crwdns2935283:004/24/16crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
I've used this info at least twice over many years to disassemble a Sony TR3.. thank you to those who provided it!
Medtech1 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 1,252
