Sony Vaio PCG-4G1L Keyboard Replacement
    1. Sony Vaio PCG-4G1L Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off the computer and disconnect the charging cable.
      • Failing to unplug the cable can result in electric shock.
    2. Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide battery release toggle switch towards the "RELEASE" print.
    3. Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Apply pressure with your thumb on the grip.
      • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
    1. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
    2. Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
      • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
    3. Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Keyboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
      • Use the plastic opening tool to release the clamp.
      • Using slight pressure, remove the ribbon cable with your fingers.
Cole Collins
crwdns2935283:010/04/16crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-3, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 2-3, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S2G3
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 1,305
