Sony Vaio PCG-4G1L Hard Drive Replacement
  1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
  7. Sony Vaio PCG-4G1L Hard Drive  Replacement, Network Antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Swivel the Network Antenna up so that it points upward.
  8. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch thumb and index finger at the Network Antenna's base.
    • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
    • Pull the Network Antenna off.
  9. Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
  10. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
  11. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable by using the precision tweezers.
    • Slowly pry out the ribbon cable by using the plastic opening tool.
  12. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
    • Remove the plastic cover by inserting the plastic opening tool around the edge.
  13. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon cable by pulling straight up with your fingers.
  14. Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 5 mm Phillips #0 flat head screws using a Bit Driver with a Phillips PH000 bit.
    • Remove the bracket with your fingers.
  15. Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Vaio PCG-4G1L Hard Drive  Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, pry out the side of the hard drive.
    • The hard drive should easily disconnect from the connector.
    • Slide the hard drive out, towards the left side of the case, while your fingers apply pressure to the ribbon cable.
Diego Fabiano
crwdns2935283:010/04/16crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-3, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 2-3, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S2G3
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 90
crwdns2942667:0crwdne2942667:0 11,552
