Sony Vaio PCG-432L RAM Replacement
  1. Sony Vaio PCG-432L RAM Replacement, Opening up the Notebook: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-432L RAM Replacement, Opening up the Notebook: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the computer over, and remove all screws circled in picture provided.
    • Set these screws aside for later in a place they will not be lost.
    • Flip the computer over and open the lid. Then take the trackpad/wrist-rest off the computer slightly but not too fast because there is a ribbon cable to disconnect. Once you have disconnected the ribbon cable set aside the assembly
    • Be careful! There is a delicate ribbon cable to detach before fully removing the assembly. Damaging/ripping this cable will render your trackpad useless.
    • Push the two white pieces holding the RAM aside and then push the RAM up.
    • Remove the RAM from the computer and set it aside.
    • Insert your replacement RAM into the slot, then push down gently until the plastic holders click and hold the RAM into place.
    • If the RAM does not go down fairly easily when you put it in, adjust it, don’t keep pushing because that’s an easy way to break your RAM.
    • Re-connect the ribbon cable from the trackpad/wrist-rest, then place the assembly down onto it’s mount and close the computer lid, and then flip it back over.
To reassemble your device, follow step 1 in reverse order.
[deleted]
crwdns2935283:008/28/18crwdne2935283:0
27.899 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 646
