Sony Vaio PCG-161L Speakers Replacement
  1. Sony Vaio PCG-161L Speakers Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Speakers Replacement, Speakers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
  6. Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
  7. Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top casing by lifting up on the plastic exposing the two speakers.
  8. Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm screws attaching the broken speaker to the casing.
    • Each speaker has two 4mm screws holding it to the casing. If you are removing both speakers, remove all four screws.
  9. Sony Vaio PCG-161L Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wire from the board by pulling the wire out of the harness.
    • These harnesses do not have any clips or tabs. Simply pull on the wire and it will come out of the harness.
Roman Alshehri
crwdns2935283:003/08/17crwdne2935283:0
407 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 crwdns2935289:0UMass Dartmouth, Team S3-G2, Botvin Spring 2017crwdne2935289:0
UMASSD-BOTVIN-S17S3G2
crwdns2942667:0crwdne2942667:0 435
