Sony Vaio PCG-161L Hard Drive Replacement
  1. Sony Vaio PCG-161L Hard Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 mm screw on the left side of the battery that holds the casing to the device using a phillips head screwdriver.
  6. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down and remove the other 6 mm screw holding the casing to the device using a phillips head screwdriver.
  7. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top casing by lifting up on the plastic.
    • There are no longer any wires connecting the casing to the motherboard. The casing can be fully removed and put to the side.
  8. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The ribbon cable covering the hard drive and connecting to the motherboard is held in using zero insertion force (ZIF) connector.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps, then pull the ribbon cable out.
  9. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 5 mm screws holding the hard drive to the motherboard.
  10. Sony Vaio PCG-161L Hard Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable connecting the motherboard to the hard drive by pulling the female connector off of the pins attached the hard drive.
Roman Alshehri
crwdns2935283:003/08/17crwdne2935283:0
407 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 crwdns2935289:0UMass Dartmouth, Team S3-G2, Botvin Spring 2017crwdne2935289:0
UMASSD-BOTVIN-S17S3G2
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,264
